...then place the band around the klickys head...
(if you are a sensible person, you might skip the next few images...
...and turn and turn the band very tight around the neck.
The accumulated force of each turn of the band is used to push the head upwards,
away from the shoulders, so best is to be as close as possible at the grate between
torus and head, and to place the next turns below the first ones, which gives them
a little more direction upwards...
